From polyhedric/multifaced mesh to polygonal mesh
3 ANTWORTEN 3
Nachricht 1 von 4
marco_savarino
319 Aufrufe, 3 Antworten
I did a 3D model with Revit2022 and now I have to export it in SAP2000. I exported the Revit file on Autocad and the elements are classified as "mesh poliedrica" (I'm Italian, so i think it is poyhedral/multifaced mesh), but to import elements on SAP i have to transform these elements into "mesh poligonale" (that i think is "polygonal mesh"). I tried to create "polygonal mesh" with the "3Dmesh" command, but it's a slow and manually process, so the question is: is there a command that automatically transforms "polyhedral mesh" into "polygonal mesh"?
I can attach the file i am wornking in, if someone is avayable to help me.
Hope for your help. Thanks.
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: marco_savarino
When you export, did you choose ACIS Solid?
In AutoCAD did you use convert mesh?
Nachricht 3 von 4
marco_savarino
als Antwort auf: syman2000
I exported from Revit not as ACIS solid, but as Polymesh and i attach the result (file named: "1").
I know i can convert the reslt in Mesh, but it is only Mesh element, i need a Polygon Mesh (as in the file named "2")
Nachricht 4 von 4
pendean
