Friday Feature #4 Create a Revit family Contest
Viveka_CD
Alumni Alumni
Message 1 of 37
Viveka_CD
Hello Awesome Community! Heart
Welcome to Friday Feature Series # 4
As part of this series, and an idea  initiated by our very own @Ilic.Andrej:We want to ask you to create and submit loadable Revit families
You can use Family Editor Tools or Create a Family from a Template or even apply Advanced Loadable Family Techniques
Feel free to add images or screencast to show the steps.
We would love to hear from you! Smiley Happy
*The best entry (based on top voted - max kudos) will be selected and announced as the winner of a surprise gift!
Happy creating - looking forward to your entries!
Meanwhile, read how Louvre Abu Dhabi Wants You to See Humanity in a New Light
Louvre Abu Dhabi is designed by architect Jean Nouvel and engineering services by  BuroHappold Engineering
Accepted solutions (3)
Replies (36)
Message 21 of 37
@chrisplyler
I actually haven't created any two-level family, ever.  Thanks for make it to the list of things I need to be doing.
Message 22 of 37
SteveKStafford
@ToanDN wrote:
My point is that a drop-down list of options is already available via Family Type parameter, in answer to @Ilic.Andrej comment that he had deemed it was impossible.
@Ilic.Andrej wrote: "I remember trying to find out how to create a parameter which provides a drop-down menu."
I read his words differently from what you are writing. He is interested in a parameter that could provide users with a preset drop-down list. As you know the reason the Family Type parameter has a drop-down list is because it is intrinsically tied to loaded families. It wasn't obvious to me I could use that fact to help me. Then my friend Jose Fandos pointed out to me that I could take advantage of it by using a dummy family to hold the information I wanted to share in a list. Light Bulb! (using Gru's voice)
If that's obvious from the help file or to you, then you're more clever than me. Cheers!
Steve Stafford
Message 23 of 37
chrisplyler
@ToanDN wrote:
@chrisplyler
It's pretty handy for stuff that suits the condition.
Message 24 of 37
Sahay_R
That's how I got the upper addons to switch around on my workbench family.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 25 of 37
constantin.stroescu
When I create my Revit families I try to make them so to be as adequate as possible to what I need in the project.
Here are some examples:
  1. Nested parametric families with Shared Parametrs - when I need frequent dimension changes of the components. As an example a wooden structural column with a steel connector placed at the bottom of it. The bolts and bottom steel connector are nested into the Structural Column Family and then this is loaded into the project as a structural element. In this case I use Shared Parameters ,  so to be sure they will work together when dimensions of the components will change.
2. Some times it happens that I need a very special piece of furniture, one that the owner of the space already have bought it. So as in this Seat unit family that I had to use in a public hall. In this case I used only parameters of material. The modeling was made in Revit, I used nested families but no geometric parameters:
3.  sometimes when I need rough objects to be figured in my drawings/renderings I use families with instance parameters in order to obtain a large variety of forms using a single family. In the next example I've made a bunch of potteries all in one family. Every instance has different geometric parameters and material.
Constantin Stroescu
Message 26 of 37
@SteveKStafford  Oh come on Steve, don't take it the wrong way.  What you showed are plenty smart and I thank you for sharing it.
@constantin.stroescu  Very well done, both the work and the step-by-step tutorial.
Message 27 of 37
Viveka_CD
Thank you @constantin.stroescu very informative.
Great post and easy to follow steps - beneficial to the community!
Message 28 of 37
Sahay_R
@SteveKStafford - dummy families - what a concept! I will use that for more family situations where there is no interchangeable part.
Rina Sahay
Message 29 of 37
Hello everyone,
This is my first post here so I hope I'm doing this right 🙂
I made a small sailing boat, that you can either look at with the mast/sail built up or dismantle for storage (different types)
Also I added a instance parameter with which you can show/hide a rope so the boat can be hung onto a hook.
As you can see in the Pictures below (I created them with Enscape)
I attached my Family too. So if you want you can have a look at it 🙂
Have a nice rest of your week everyone!
Message 30 of 37
Viveka_CD
Hi @Anonymous (that's a cool name Smiley Happy) sounds like someone with superpowers..
Thanks for participating and taking time to post!
A warm welcome to the Autodesk community.
Message 31 of 37
Steve, I have been a long time admirer of yours.  Met you many years ago at AU shortly after Revit was purchased by AutoDesk.  I love the concept of your family but am afraid there might be some problems with it.  Have you tried to open the family or create the same type family in 2017?  I am getting very unusual result with the family crashing out 2017.  I will need to try it with 2018 tomorrow.  Please see video below to see what is happening on my end.
Thanks again for sharing your genuis.
Also, to Toan if this process is so well documented maybe you will have some input on what is causing the problem (also an admirer of yours) I know you are extremely helpful to many people.
[video]
Not sure if I inserted the video correctly so here is a link: Bug in Revit 2017 family
Message 32 of 37
@Anonymous
His family works fine here after updated to 2017.  No 2016 popup as shown on your video.
Message 33 of 37
@Viveka_CD
Thanks for the welcome!
Hehe, yes it's the name of my Youtube Channel. I make videos about Revit and other BIM software 🙂
Message 34 of 37
Viveka_CD
Hi @Anonymous
I admire people like you who appreciate others efforts.Smiley Happy
Message 35 of 37
Viveka_CD
Hi All,
Just a friendly reminder to cast your votes by 7PM EST
Message 36 of 37
Viveka_CD
Hi All,
The winners of Friday Feature #4 Create a Revit family Contest are:
@Ilic.Andrej for the furniture family and
@constantin.stroescu for the Nested parametric families with Shared Parameters
Congratulations to all participants!
We had great submissions from @Anonymous, @Anonymous, @Sahay_R@chrisplyler, and @SteveKStafford
Glad to see entries from new members as well!
Happy Holidays and look forward to more exciting contests in 2018 Smiley Happy
Message 37 of 37
SteveKStafford
@Anonymous I didn't see your reply until today. I'm sorry you ran into issues with the example. When I opened the file I shared earlier, using the same version/build of 2017 as you, I used Save As to save the file in 2017 format (attached below). I got the message that it was upgrading to 2017 from 2014. It also has a nested detail family that provides the list of choices.
Note, I didn't load (drag) it into a project and use edit family. I opened the file itself and used Save As. FWIW, I have been working to break the habit of using Edit Family from inside projects, if I'm going to do anything that changes it. When I created that example file it was stripped out of a nested family itself (door panel) and renamed so it could be generic. It never went straight into a project, it was used in a host family to control options for the door panel (raised panel and trim moulding around them).
I suspect the crashing you experienced has to do with the dragging and dropping combined with the Save As after using Edit Family. I couldn't tell if you still had the 2014 version open in the background when you were working with the 2017 version. Regardless; opening, upgrading and using Save As directly on the file should avoid the crashing.
Thanks for the kind words, Happy Holidays and all the best!
Steve Stafford
