First of all, feel free to point me to the correct place if this is an incorrect board for this post.
When I use the Launch Active Model tool of the CFD add-in, Autodesk CFD launches normally but soon stops responding indefinitely (up to 50 minutes and no change at all). This also happens when I export to ACIS first and then open the geometry with CFD.
This workflow has worked for me before, and with similarly complex geometries, so I think there must be something in the Revit model that is not friendly with the exporting process.
How can I troubleshoot this problem? Are there any features/elements/families that I should avoid?
Thank you in advance.
Pol
