Framing view
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
glkirk
392 Aufrufe, 2 Antworten
Framing view
In the template that I use, it has "Second Floor framing", as well as FFF.
I would like it to show the walls.
Can anyone help me understand how this works? Seems that almost any "View Range" setting should show the walls.
The walls are on in VG
Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: glkirk
Your View Discipline (Structural) is acting on the View.
Change it.
Nachricht 3 von 3
francfiles
check the discipline you're using for your view. If it's structural, wall usage should be structural to make them visible on the plan
