Does Revit 2020 have a Frame Generator extension? We'd like to model a metal building and noticed that older versions of Revit had this extension but it seems to no longer be available. Or perhaps it's called something else now?
No longer. REX 2018 was last version.
There is a subscription add-in you can buy. Pricey, but excellent.
https://strucsoftsolutions.com/
...or just use Columns and Beams, or Curtain Walls.
Is there anything made by Autodesk that has taken its place that we could use to do this?
We are looking to use our existing license to accomplish this.
@Anonymous wrote:Is there anything made by Autodesk that has taken its place that we could use to do this?
Yes, I mentioned it above. Columns and Beams. Or you can get there with Curtain Walls.
Perhaps check some steel framing manufacturers see if they provide any.
https://www.clarkdietrich.com/support-tools/bim-systems
https://www.steelsmartsystem.com/steel-smart-framer-light-steel-framing-bim-software/
