the foundation wall dosent appear in a floor plans after i draw it why ?????
they give me this message
((None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.))
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Have you checked at which level you are drawing the wall? if you are in the 1st floor and the base level of the wall is, let's say, GF and it's not tall enough you won't see it..Other options are that visibility setting are hiding walls, maybe they are unchecked?
You can try:
1. Adjust View Depth/cut plane
2. Use an Underlay in your Floor Plan view to show the Level below ( foundation )
Make sure that you are in a wireframe view, so that you can see through the floors.
@omarqassem94 wrote:
*Of course i am on wireframe but i think the system dosent allowed the
foundation wall to appear in the architecture view *
It does. You just need to adjust the View Depth.
