Formula to calculate the area of the 2nd floor divided by the 1st floor
4 ANTWORTEN 4
Nachricht 1 von 5
415 Aufrufe, 4 Antworten
I was wondering if it's possible to create a formula in an area schedule that would allow the area of the 2nd floor be divided by the 1st floor.
4 ANTWORTEN 4
Nachricht 2 von 5
Alfredo_Medina
als Antwort auf: Anonymous
For this type of operations, I suggest to export a schedule of floors from Revit to .txt. Then, open that file in Excel and add formulas that relate to the value of a cell.
Nachricht 3 von 5
Sure. Manually enter the Floor Area of Level 2 into a second Project Parameter Field Column in the Schedule and then create another Column which computes a value based on the Calculated Formula =Area/[the manually inputting value].
Nachricht 4 von 5
als Antwort auf: barthbradley
I was hoping to avoid manual input so that when the form moves the area adapts.
Nachricht 5 von 5
For a starter, add a Calculated Value parameter and choose Percentage instead of Formula.
