I input a formula =
round(L*0.08)
for a value round down but responded as "unit not identical"
Please advice
I input a formula =
round(L*0.08)
Please advice
Check the type is the parameter you are adding the formula to and the type of the parameter L? Are they length or number?
this L is itentical to other normal parameters (length, type...)
and once I add "round" to other parameters, same message appear so that means the script is the problem
see enclosed
Sorry I am receiving and replying to posts via email so I cannot see attachments
To round up length you need to
1. first neutralize it (make it unitless) >>
2. round it up or down >>
3. then reapply the units ...
Use the formula below (replace mm for inch or feet or whichever units you use/need)
round((L * 0.08) / 1 mm) * 1 mm
You can replace round with roundup or rounddown whichever is convenient
