Hi everyone,
please, I need help with writing this formula. As shown in the image, I want to write a formula that will copy or register the dimensions up into the filters down.
То copy the value of a parameter, just write the name of that parameter into the formula. Both parameters need to be of the same type. Is that what you wanted?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
When I just write the name in the formula, an error message comes up which says "inconsistent units". Is there no formula if its deferent types?
There are ways to do it. What kind of parameter types you used?
Andrej Ilić
MSc Arch
The one that I want to copy from is:
Discipline = Common
Type = Lenght
The one that I want to copy to is:
Discipline = Common
Type = Text
Sadly, that is the only conversion that cant be done.
Andrej Ilić
MSc Arch
Revit should make a function like that at one point. It is very useful.
Thanks for your help.
I agree.
Andrej Ilić
MSc Arch
Hi @jegU5TJE
Interesting idea. I've posted your idea on the ideas forum, please add comments and vote for the idea to get considered.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
