please help - having a complete brain fart on a simple forumla
I need to create a door tag which shows either SC for self closer or SF for free swing in the tag.
I want to create a parameter which is a yes/no for self closer and depending on that result a parameter call door closer type returns either the SC for SF
any help would received Kudos as I've just gone blank (i know it's simple, but it's been a long day and my syntax isn't working)
Cheers
Solved by Alfredo_Medina. Go to Solution.
In the sample below, "Closer" is a text, shared ,parameter. "Self Closer" is a Yes/No family parameter.
thanks Alfredo - yup it was me missing the "" that was the issue
appreciate your reply.
J
