Every time I import even the simplest block from FormIt to Revit, add a wall, and then a texture, it never works. It becomes pixelated and wavey. Can't find anything related to this issue. Tested it on 2018 and 2019. Watched a few webinars on the process and not sure what Im doing wrong. I did a water tight test and all looked fine. Any help would be greatly appreciated.
Created in FormIt, added a Mass wall, then tried applying a brick texture to the left wall and this is the render I get
Sorry to hear that you are having issues with the application.
Just checking if you have the latest updates installed for your Revit version?
To make sure that the issue you are seeing is not something already fixed in one of the product updates, I would suggest checking the Desktop App to see if there are any Revit updates available. For information on using the Desktop App see the following article: About the Autodesk Desktop App
Note: If you are not able to download updates through the Desktop App, the following article has information on downloading updates through the Autodesk Accounts page:
Install Updates, Add-ons, and Enhancements
Can you share a file and screencast of the issue?
I look forward to hearing from you!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Yes I'm on 2019.2. I attached an image to this post. What does a screencast do?
Here is a quick video when I add a wall with no texture selected
