Formatting for sheets across computers differs
4 ANTWORTEN 4
Nachricht 1 von 5
229 Aufrufe, 4 Antworten
I have created a template sheet for another company in exactly the same version they have and have found that they both format differently. the boxes that contain text have been cut short and so words are missing when loaded into their Revit but appear absolutely fine in mine. Is this a known issue? or is their some kind aspect ratio i'm missing?
4 ANTWORTEN 4
Nachricht 2 von 5
cbcarch
als Antwort auf: Anonymous
Check the Labels in the Titleblock Family. You can drag the dot to increase the length for text characters.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 5
als Antwort auf: cbcarch
Indeed this might sort the issues. How ever it does not explain why I am seeing one effect on one computer and another on another.  I have found that I do not even have to extend them to show the missing text if i click to edit the text it all appears, so the box is big enough it just seems to be some strange formatting issue.
Nachricht 4 von 5
RobDraw
Possibly a different font definition.
Rob
Nachricht 5 von 5
als Antwort auf: RobDraw
Thanks, Could you elaborate?
