Footings Missing in Section
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
2377 Aufrufe, 13 Antworten
I'm frustrated and don't know what to do.  Why are my footings not visible? How do  I make them visible?  They don't even show up when I reveal hidden elements.  How can this be?  Where did I screw up?
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: Anonymous
Additional screen shots to help with the issue (I hope)...
Nachricht 3 von 14
Change the topography category to transparent.
Nachricht 4 von 14
als Antwort auf: ToanDN
Do what now?
Nachricht 5 von 14
Select the topo, right click, override by category, surface transparency = 100%
Nachricht 6 von 14
Where's the cut plane? Does it intersect with the footings?
...might even try raising your topo poche to reveal the footings within the primary view range.
Nachricht 7 von 14
We normally show footing not cut by the section line like this.
Nachricht 8 von 14
Same here.
Via Show Hidden Lines (View Tab) and/or View Discipline.
Nachricht 9 von 14
I like that!  Is that drawn with detail lines?
Nachricht 10 von 14
als Antwort auf: barthbradley
No, the section cut plane did not intersect the footings.  I figured out how to cut the section, though, and run part of it through the footing, so that helped...
Nachricht 11 von 14
Change Discipline to Structural (if Structural Elements) or use Show Hidden Lines tool.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revit-DocumentPresent/files/GUID-0C893628-9560-4913-8A44-2E61DD3ACBC0-htm.html
Nachricht 12 von 14
No.  Use Show Hidden Lines tool on the View panel.
https://knowledge.autodesk.com/community/screencast/5df89e1c-89c6-4bf0-8e73-9808c2338747
Nachricht 13 von 14
Thanks, that really helps!  Most of my drawing disciplines are set to coordination.  I had no idea about the hidden line tool.
Nachricht 14 von 14
The trick to using the Show Hidden Line tool, which escapes many, is to go into a Wireframe mode, and then select the element to be hidden first, and then the element that is hiding it.  When you return to Hidden View, the hidden lines will be shown.   Remember, the View 's Show Hidden Lines (under Properties) must be turned on also.
