So, I finally found an easy to place footings under walls.
But now that I have detailed the foundation and need to move the footings under walls to be more centered, I keep having this extension problem.
Does anyone know if there is a way to work with it?
Thanks!
Change the footing's "Eccentricity" value.
...or, are you asking about this?
Thanks Barth,
But I tried both those things.
Changing the eccentricity does move the bulk of the footing wall, bu the ends continue to extend.
I tried dragging the dot- no luck
Tried Trimming-extend-no luck.
I'm wondering if there is no way except to build with the proper thickness wall instead of adding something later.
BTW I also tried joining my new wall to the existing-no luck
I'm not understanding what you want to do, but the footing is fully parametric, so you can resize it - or create additional Types of different sizes.
If you can post a picture showing what you are trying to achieve, that might be helpful.
