Footing stops at wall join.....
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
frankSRFZD
459 Aufrufe, 6 Antworten
I have one foundation wall that every time I add a footing to it, it stops the footing from the adjoining wall to stop and not continue to wall end. I have tried removing and re-adding all the walls, I have verified the heights and sizes of the walls and the footing, I have tried disconnecting and reconnecting the wall, and I have also tried to adjust the wall join, but nothing seems to change it.
Any ideas?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: frankSRFZD
I don't understand what you're showing or describing, but it almost sounds like a Phasing issue. Why don't you post the file and let us have a look and see.
Nachricht 3 von 7
Nachricht 4 von 7
frankSRFZD
als Antwort auf: ToanDN
I try to select mutiple walls for the footer placement but it still does the same thing.
Nachricht 5 von 7
frankSRFZD
Here is the file....I finally stripped out enough families to get the file size to post.
Nachricht 6 von 7
Reset Wall Profile.
Nachricht 7 von 7
frankSRFZD
Thank you. I didn't even see that the curb cut was in the wrong wall.
