Okay, big issue first. I have to change all the fonts in all the families in a project to Simplex with .8 width factor and bold styling. (it's a huge pain, I know)
Now for the problem at hand. How can I change the "DN" symbol on stairs to match my standards? The "Type Properties" window has options for the font, but not for the width factor and boldness.
I tried ccollins' solution, but it didn't work.
If there's no solution, I'll just hide the text and put a dummy "DN" on all the stairs.
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
@ToanDN
That was the solution in the other thread. I already tried it and it did not work.
Wow--you found an old thread from my past life.....
Trick: If you have access to a font editor, you can create a new simplex font with width factor of .8, save it into C:Windows/Fonts with a unique name, and load that into the Stair text type.
Note: it must be a True Type Font--see this:
@cbcarchwrote:Wow--you found an old thread from my past life.....
Thanks! I can do that.
