Font is coming out during plot
4 ANTWORTEN 4
Nachricht 1 von 5
RJK42
341 Aufrufe, 4 Antworten
I'm using Revit 2017 and have everything ready for the potter. I typical plot to PDF so I can save my files but when I do the font is all screwed up compared to the what is in the project.  I haven't done any thing different.
4 ANTWORTEN 4
Nachricht 2 von 5
-FDC-
als Antwort auf: RJK42
What font is it.
Try changing it to arial and see what happens.
PDF doesn't support all TrueType fonts.
Nachricht 3 von 5
RJK42
als Antwort auf: -FDC-
sorry - I meant "text" doesn't matter what. When ever I print, the text is either way too small or big. I actually when into my display settings and adjusting the scaling which fixed the issue, but regardless of that, the text looks fine in revit so why does it matter if the scale needs to be adjusted in the Microsoft windows display setting?  It should print out exactly what is being displayed regardless.
Nachricht 4 von 5
-FDC-
What do you use to create your pdf?
Nachricht 5 von 5
RJK42
Adobe
