Folded section
Folded section
Message 1 of 10
Folded section
Good afternoon.
I'd need to create ONE section through the red line on the attached image. The thing is that this red line is angled.
I was trying to make 2 sections and then make an overlapping to get 1 section but it does not look good or probably I am not knowing how to make the accurate overlapping...
any suggestions please?.
Replies (9)
Message 2 of 10
Message 3 of 10
no, I do not Dynamo
Message 4 of 10
I notice you only have 2 sections. You can't get what you want by cropping the views?
Message 5 of 10
Make two sections with a shallow depth of view.  The point where they meet should be an open area, not cutting or close to any significant objects.
Message 6 of 10
No. I did not get a solution fir this. I do not do dynamo
Message 7 of 10
I tried that by making 2 sections and then placing them together, I don't even know if is possible to make something like I am showing in the attached sketch
Message 8 of 10
Corsten.Au
Cycle Section tail and you can get that graphical representation...
Select the Section, and at the edge you can cycle the option whether to show the tail, head or non..Select the Section, and at the edge you can cycle the option whether to show the tail, head or non..Just one section. if you dont want to show two references..Just one section. if you dont want to show two references..
Corsten
Building Designer
Message 9 of 10
Not like you are showing. I don't mean a single view; I mean two views matched together on a single sheet view.
...I am curious though, @Anonymous: what information needs to be documented in these two vast expanse section views?
Message 10 of 10
Corsten.Au
To make accurate overlapping ..Use
a simple reference wall... ( create it at exact intersection of two section views.. )
Basically you need a 3D element to match the view / overlap..
Corsten
Building Designer
