Floors Hidden lines
18 ANTWORTEN 18
Nachricht 1 von 19
mairh_tsek
1048 Aufrufe, 18 Antworten
Floors Hidden lines
Hello all,
I have a floor in Revit with multiple slopes. I dont want to see the slope lines so in the VG I turned them off, but when I print in PDF I see their possition.
Do you have any idea how I would not see them ?
Thank you!
18 ANTWORTEN 18
Nachricht 2 von 19
Sean_Page
als Antwort auf: mairh_tsek
Do they still show if you tab through and Hide in View?
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Nachricht 3 von 19
mairh_tsek
als Antwort auf: Sean_Page
Thank you for your answer,
When I press TAB, I can select the floor
Nachricht 4 von 19
Use the Linework (LW) Tool on the Modify Tab.
Nachricht 5 von 19
mairh_tsek
I have many slopes and 4 floors with large long, so the LT it will take me a lot of time.. what I did it was to keep the hidden lines on, and to gave them the same color as the surface of the floor. The result is better but I can still see them in the pdf
Nachricht 6 von 19
 Are you saying that the PDF shows that linework even if you override the Floor's Projection Line Color to be the same color as the Material's Graphic Color?
What is the View's Visual Style?
Nachricht 7 von 19
mairh_tsek
als Antwort auf: barthbradley
I override the color of the projection lines to be the same as the color of the surface (Image 1). and the result in pdf is in the image 2. In Revit, if I don't select the floor I don't see the lines.
Thank you for your time!
Nachricht 8 von 19
What's the View's Visual Style? Are you processing the PDF as a Vector or a Raster?
 ...try using the "Replace halftone with thin lines" option in the Print Setup dialog.
Nachricht 9 von 19
No issue here using Export to PDF in Revit 2022.
With Interior Edges visible:
With Interior Edges Invisible:
Nachricht 10 von 19
mairh_tsek
als Antwort auf: ToanDN
Actually in your pdf you have the same problem as me...you see the white lines where you had the slope
Nachricht 11 von 19
mairh_tsek
Visual Style : Hidden Lines, Vector Processing, Printer : PDF-XChange Standard
"Replace halftone with thin lines" : Nothing happens
Nachricht 12 von 19
You know, I'm not able to replicate. Have you tried another PDF printer?
Nachricht 13 von 19
I don't know what pdf viewer you are using but I don't see those line in my AdobePDF.
Nachricht 14 von 19
Lachlan-JWP
I get very faint lines in Adobe Acrobat Reader DC, but it's far more noticeable when viewed in my web browser (see below)
@mairh_tsekwhat pdf viewer are you using?
Nachricht 15 von 19
mairh_tsek
als Antwort auf: Lachlan-JWP
In both Adobe Acrobat Reader DC and PDF-XChange Editor I have the same result
Nachricht 16 von 19
Lachlan-JWP
It appears that I can't replicate this issue either.
Here's my own attempt. The interior lines disappear as expected.
I've also attached my project file & a print pdf for comparision.
Nachricht 17 von 19
Lachlan-JWP
Oooh, I can see the lines when I preview my uploaded pdf but not when I download it. Can you download my pdf and see if the issue is still there for you. This is starting to look like a graphics issue.
Nachricht 18 von 19
mairh_tsek
Thank you for the test. When I download your pdf and open in with Adobe Acrobat Reader DC, I dont see the lines. But when I open it with PDF-Xchange Edit I see them.
In my case when I open my pdf with both pdfs readers dont work
Nachricht 19 von 19
Export to Raster PDF:  no lines
Export to Vector PDF:  only see the lines if I zoom in very close in Adobe Acrobat pro 2020
@ 6400% zoom level of a 8.5x11 PDF
@ 100% zoom level of the same PDF
