I'm working on a model with many levels close to each other (not a building) and my plan views are showing floors below that are not within the view range. I no not want to see these floors that are outside of the view range. Any advice is appreciated.
Gelöst! Gehe zur Lösung
Gelöst von Karol_Piroska. Gehe zur Lösung
yap, that's the way Revit works. If "floors" are too close (1.2m or 4ft) both will be shown. I would love to know the logic behind this myself. Pretty much a nightmare if you work on industrial structures.
You can only manually hide it, filter them based on some parameters or worksets.
