Hi!
I just received a model from a contractor in which I intend to extract some 3D images in order to illustrate the construction process, but when I set the 3D views some floors appear with a ton of transparency, I've already checked the visibility/graphics options, the material of the floors, and the object styles options and everything seems to be ok with no transparency or whatsoever. I don't know what is causing this transparency issue. You can see how the floors appear in the attached image.
Thanks so much for the help! Cheers
Gelöst! Gehe zur Lösung
Gelöst von RevitRx. Gehe zur Lösung
Could you provide more information about the current config?
I suspect that the element of the category floor or is it for example a structural framing?
If this project is linked you might want to check the v/g settings for linked file, and change the settings of links to custom to modify the visibility settings.
It could also be a parameter in v/g as underlay or greyscale.
Just based on what I'm seeing in your screenshot, I'd say it's being caused by the Section Box. Raise or lower slightly. Does it change from looking transparent?
Post the file.
Agreed, post the file(s).
It could be a material asset issue, it could be a phasing override, it could be a view filter, or it could be a whole bunch of other things.
Does this appear in all/one/none: Shaded with Edges, Hidden Line, or Realistic? Only in 3D views, or all plans/elevations/sections? I'd also look into subcategories and check and see if any of the elements were overridden.
Hope this points you in the right direction.
Thanks to everyone that posted!
I figure out what was the problem. The floor items that appear with certain transparency had an "Override graphics in view" transparency set to 40%, a difficult thing to notice.
