The height of the building is 6000mm
There is a level 0 and a level 1
When I try to place furniture on level 0 it's doesn't appear of 3D view the furniture team is below on level 0 instead of on level 1. May any please help, I'm need of an assistance. I'm using Revit 2022
Thank you
@220635163 wrote:The height of the building is 6000mm
Thank you
You placed them on level 0 so they are on level 0...if you want them on level 1 then you should open the view for level 1 and place them there...
Alternatively use one of the following:
