Floorplan and RCP show as same level in section
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
809 Aufrufe, 4 Antworten
Help!  I am a student learning revit and somehow my floorplans and my ceiling plans show as a single level in section elevation.  I have separate views, but there is just a single level in section...see screenshot attached.  Is there anyway to fix this other than redrawing the whole thing?  UGH - how did I pull this off?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Because you renamed the ceiling plan view and subsequently renamed the level, affecting the floor plan view name.
Just rename the level back to Level 1, answer No when it asks you if you want to rename views.
Nachricht 3 von 5
als Antwort auf: ToanDN
If I rename the ceiling plans, will I lose all that work?  All my varied ceiling heights and lighting are already in.
Nachricht 4 von 5
Calm down. You are not going to lose anything.  Promise.
Can you elaborate on what you think your predicament is? I'm not quite understanding.
Nachricht 5 von 5
No you will be fine.
