Floor/wall join removes wall in elevation
2 ANTWORTEN 2
Nachricht 1 von 3
281 Aufrufe, 2 Antworten
Good morning,
at our office we've just started using Revit for architectural purposes.
This week i ran into a problem.
I joined a compound wall to a compound floor. If i look in a section this looks okay, but you can see the floor line at the outside of the wall. In elevation view this results in a cut wall. (see attached pictures/project)
I have tried to make 2 floors already, but then i cannot join the inner walls properly to the floors.
Can somebody help me with this problem?
thank you!
Beschriftungen (2)
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: Anonymous
you can try this and see if helps. thanks
Nachricht 3 von 3
als Antwort auf: ennujozlagam
thanks for your response. I forgot to mention that we us Revit LT, so i don't think i can create parts?
