Floor slab does not show up in elevation
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
1777 Aufrufe, 6 Antworten
Site Floor slab doesn't show up in elevation which has been cut but shows up in sections which have been drawn in the same location. Thanks for any help
6 ANTWORTEN 6
Nachricht 2 von 7
Viveka_CD
als Antwort auf: Anonymous
Hi @Anonymous
Can you check if the floors are checked in the visibility graphics settings?
Also, check your view range settings and is the floor slab a foundation slab?
Nachricht 3 von 7
als Antwort auf: Viveka_CD
Yes, I checked them, but the issue was not that. I have attached the file for clearance. Thanks,
Nachricht 4 von 7
chrisplyler
It's hidden by element.
Come on now...when something is missing, isn't the Reveal Hidden Elements button the first thing you check?
Nachricht 5 von 7
Viveka_CD
Hi @Anonymous
Hope the post by @chrisplyler on reveal and unhide hidden elements helped resolve your issue.
Let us know if you have additional questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Nachricht 6 von 7
I checked it, but don't understand what happened, Thank you
Nachricht 7 von 7
Someone selected the floors and Hide Elements in View.
