Hello again.
i am now trying to move my entire project and the levels down, but when i move everything down manually, all the floorplans disapear with all the work that has been put in to them, i know i can regenerate the plans, but is there a way that i can move the project without the plans disapear?
open an elevation view
dimension betwen each level designator
change the level value
all levels should follow that initial change if your dimensions are locked
your view ranges at each level may need to change depending on how you moved the model.
Why do you move your model down? There are better ways if you just want to change Levels' elevations.
Still trying to correct for that IO, I see. You don't need to start a new thread. Just continue the other one.
Re: Internal origin problems - Autodesk Community - Revit Products
I asked if you could post your file. Can you?
