Floor plan to Sheets
n11439343
Observer Observer
n11439343
Observer
Observer
Is is possible to rotate my floor plan 90 degrees while placing it on the sheets in Revit
almeshal_mohammed
M_Meshal
Yes sure do the following:
Select the plan after placing on the sheet, and from properties pallet, look for "Rotation on Sheet" parameter and change it from None to 90 degree (Clockwise or Counterclockwise).
n11439343
Observer
Observer
Thanks a lot! That worked perfectly for me.
