Floor plan render without shadows
Hi.
I want to render a floor plan for client presentation.
I've attached a draft rendered image of my floor plan.
I made a dublicate of my 3D building, used a section box to find the right level and set my view to the top.
Even though i turned shadows off before rendering, the shadows are still there when the rendering is done.
How can i remove them from my rendered floor plan?
constantin.stroescu
You can obtain such a result using Sun settings in Solar Study > Lighting:
  • Azimuth : 180,00
  • Altitude : 0,00
it works for all 3d views:
and render images:
Constantin Stroescu
italonge
I've tried to put 180º in Sun Config, its ok, the shadows doesn't appear, but the colors is too bright... So, how to soft the Sun brightness?
Intuos5
You can fiddle around with the exposure settings of the render and alternatively change the material appearance properties in the material editor.
