Floor plan "Shadow on" is greyed out, please help!
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
2209 Aufrufe, 12 Antworten
Only one of my floor plans shadow on is grey, I checked all the settings seems fine.
Please help!
12 ANTWORTEN 12
Nachricht 2 von 13
mauricio_mssf
als Antwort auf: Anonymous
You have checked shadows in the view configuration (or view configuration of the viewtemplate)
type VG and deselect the shadow option, or disable in viewtemplalte as in the image below.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Nachricht 3 von 13
Do you have a Template assigned to the View?
Nachricht 4 von 13
als Antwort auf: barthbradley
Hi, how do I know I assigned to a template? Thanks
Nachricht 5 von 13
als Antwort auf: mauricio_mssf
Thank you for your quick reply. I didn't choose any template.
Nachricht 6 von 13
It just worked!!!
Thank you so much!
Nachricht 7 von 13
Look under "Identity Data" Group in the View Properties. Does "View Template" read something other than "None"?
Nachricht 8 von 13
@Anonymous: What was it?
Nachricht 9 von 13
If the Shadow is not ticked, how the shadow would show on the screen. I am just wondering.
Nachricht 10 von 13
It was "none", I set up everything exactly like other levels but only this one didn't have shadow. I reset again and then all fine now : )
Thank you for your help!!!
Nachricht 11 von 13
I'm confused.  So "Shadows" was greyed out before and now it isn't? And it had nothing to do with a View Template?
So, what was it then?
Nachricht 12 von 13
drugs?
kidding.
Nachricht 13 von 13
chimso
I ran into the same problem, and what it was on my view was that in the display properties, it was set at a transparancy... when I changed the transparency back to zero, the box became available. It might have been a coincidence, but that is my two cents.
