I'm having a problem getting a first floor plan associated with a file that was generated in Revit 2015 to print in Revit 2017. The first floor plan displays fine. The problem is only when I try to print it. Does anyone have an idea of what might be causing this problem?
The other odd behavior here is that if I delete the first floor view and regenerate the floor plan, it does not present itself as an option in my selection of floor plans to generate. I've attached the revit file below for review.
Any help is greatly appreciated.
Mike
Gelöst! Gehe zur Lösung
Gelöst von artejon. Gehe zur Lösung
Try this:
Try to change your first floor plan visual style from wireframe to hidden and it should be OK.
