Floor patterns not visible
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
z5325340
409 Aufrufe, 3 Antworten
I have an issue in that the pattern of my floors is not showing. I have checked the 'visibility graphics and overrides' and the 'view templates' and there is nothing to indicate why it's not showing. There is also no 'plan regions' either. I simply went into >edit type< then >type properties< then >edit assembly< and then updated >surface patterns< (having found and watched several youtube videos regarding floor patterns and followed these) so I am very confused why there is still no reason why the pattern of my floor finish should not be showing.  I am using an education version of Revit 2024 Has AutoDesk added restrictions to the education version for floor patterns? It would seem ridiculous if they have because floor patterns is such a basic fundamental of design drawings.
3 ANTWORTEN 3
Nachricht 2 von 4
SteveKStafford
als Antwort auf: z5325340
If the floor category's Pattern Transparency is not overridden in Visibility/Graphics it is possible that someone used the right click Override Elements option which permits turning off the pattern. Select the floor and right click  and choose the Override in View > Elements, what does the dialog reveal? If there is a reset button active in the bottom left corner then the element has been overridden at some point.
Steve Stafford
Nachricht 3 von 4
z5325340
als Antwort auf: SteveKStafford
Thank you very much for your response. That helped greatly, that is exactly what I did to resolve this. I am the only person to have used the file, I started my design/drawings in one of the default templates. So by doing the right-click and >Overide Graphics in View then > By Category, it did permit the 'reset' option thus making floor patterns visible. However, I am not sure how that came to be set in the first place, might have been in the new file template(?) In any case, thank you.
Nachricht 4 von 4
handjonathan
Hi @z5325340
Thanks a lot for posting your question to the forums!   It's great to see you got all sorted.
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
