Floor pattern varies between revit and navis
aman.kumarRVKHA
aman.kumarRVKHA
As shown below, the tiles in Revit looks perfectly align but when I am exporting it to Navis it is following the angle at which the building is constructed. How can I match the both tiling layout.
L.Maas
I can remember this issue several years ago. I do not know if they have resolved it in newer versions. Which Navisworks & Revit versions are you using?
It has to do with that Revit has no real tools for UVW mapping which probably makes translation to other software sometimes difficult.
What you can do in Navisworks is to correct it by modifying the UVW mapping (found in Rendering).
Can be a lot of work if you have many elments to do.
You might check if it has been resolved in newer versions.
Louis
Please mention Revit version, especially when uploading Revit files.
aman.kumarRVKHA
Hello, thank you for the reply.
I am using the 2020 version.
Will try to do it manually as suggested for now.
