Floor Pattern Creation issue - Revit 2022
ansaryashiq
ansaryashiq
Can anyone assist me in creating a seamless Model Tile Pattern?
I’m working on a floor tile pattern and tried generating it using pyRevit. While it does create the pattern, the result isn’t seamless.
I would greatly appreciate your support in resolving this. I’ve attached the drafting pattern file (Revit 2022) for reference.
Thank you in advance for your help!
This post has been edited due to: @navya_gelli added the product and product version to the title to help more community members find this topic.
GHASEM_ARIYANI
First, some of your drawn lines are overlapping, so be sure to delete any segments that sit on top of one another. Overlapping geometry will always cause problems when generating a seamless model pattern.
To avoid any gaps when the pattern tiles across the surface, your pattern must be continuous on all edges:
The left and right edges must match perfectly so that the pattern can repeat horizontally without a visible break.
The same applies to the top and bottom edges — they must align and continue each other.
If you maintain this continuity on all four sides and remove overlapping lines, your pattern will generate correctly and seamless tiling will work as expected.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
ansaryashiq
Thank you for your response, will try and update here
navya_gelli
Hello, @ansaryashiq,
Just checking in—did the responses shared by @GHASEM_ARIYANI help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Navya | Community Manager
