Floor not visible in 3D view
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
10826 Aufrufe, 13 Antworten
I created a building of 3 stories on Revit 2015, the thing is the all the floors drawn on either of the floors are visible and editable in plan views, but only the ground and top floor component are visible in the 3D view, yet all floors are editable in the 3D view!!!
P.S. the floors are all of the same type!
Screenshot 01: first floor view with the floor selected
Screenshot 02: second floor view with the floor selected
Screenshot 03: 3D view with the ground and top floor elements visible and the other floor not
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: Anonymous
Didi you:
1- Check element phase and filter?
2- If floor item is marked in the VG?
3- By accident hide the element or category?
Nachricht 3 von 14
@Anonymous
1- I am not sure how to check the elements' phase and filter, but I selected the invisible floors in the plan view and in properties it is written "New Construction" as the rest of the elements... please tell me if I am doing it wrong
2- Yes, the floor is marked in the VG
3- I re-checked, no the "Temporary Hide/Isolate" is reset
Nachricht 4 von 14
ennujozlagam
@Anonymous hello, try to pick bulb if the floor is hide elements and unhide elements. please see attached.  thanks
Nachricht 5 von 14
als Antwort auf: ennujozlagam
@ennujozlagam I picked the bulb icon... the floor becomes visible but not as a hidden element... hidden elements should be highlighted in cyan when the bulb is picked!
Nachricht 6 von 14
ennujozlagam
Hello go to properties and check if it is set in a view template. Thanks
Nachricht 7 von 14
FGPerraudin
Hi Assem,
There is still a thing you haven't checked.
In the V/G dialog box, go to the filters tab.
The might be one that disables the visibility of your floors.
But actually I thing they are just hidden in the view. You do not see them in pink just because the edges are hidden by the surrounding walls.
Try both and i Hope it is of help!
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 8 von 14
als Antwort auf: FGPerraudin
@FGPerraudin I never did hide them... but they were just hidden in the view yes! Thank you :grinsendes_Gesicht_mit_lächelnden_Augen:
I picked the bulb, selected the floors, right click, and unhide in views
Nachricht 9 von 14
ennujozlagam
Nice. That's what i've said its in hide elements. Thanks
Nachricht 10 von 14
FGPerraudin
Well, it sometimes can happen via many misterious ways!
Happy it worked!
Nachricht 11 von 14
I'm having the exact same problem: a three-store building, second floor appears in floor plan but not in 3d view. The difference is when I activate the light bulb for hidden elements, it still doesn't show. These are the screenshots, the fist one is when i isolate the floor category.Sem Título-3.jpgSem Título-2.jpgSem Título-1.jpg
Nachricht 12 von 14
Select the floor on the floor plan and check its phasing.
Nachricht 13 von 14
rekhaayyasamy
CHECK TRANSPARENCY OF MATERIAL
Nachricht 14 von 14
mh-myo
CHECK YOUR PHASE FILTER PLAY AROUND WITH IT AND IT WILL GET UR PROBLEM FIXED!!!!
