Floor Modify / remove opening
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
youssef.ibrahimM37J6
1655 Aufrufe, 2 Antworten
I cut an opening on a floor using (Architecture - opening - Vertical).
 How do I modify my opening, or remove it? If I try to modify the floor, Revit is only showing me the original linework of the floor, not the linework of the opening!
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: youssef.ibrahimM37J6
@youssef.ibrahimM37J6
Hover the mouse cursor over the edge of the opening (use the TAB key if needed) and select when it highlights.
  • Edit boundary
  • Or Delete it
Nachricht 3 von 3
als Antwort auf: RDAOU
thank a lot it works fine
