floor height offset - grayed out in Properties pallet
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
micah
8678 Aufrufe, 4 Antworten
I have a floor (deck) that I need to change its height offset. However, the Height Offset From Level box in the Properties pallet is grayed out and I cannot figure out why, or how to make the needed change. Please see the attached screen shot and advise if anyone on the forum has any ideas.
Thank you,
Micah
4 ANTWORTEN 4
Nachricht 2 von 5
Alfredo_Medina
als Antwort auf: micah
@micah , Please post another screen capture that shows all the screen, including the buttons at the bottom, and the properties of the current view.
Nachricht 3 von 5
micah
als Antwort auf: Alfredo_Medina
Hello @Alfredo_Medina,
Thank you for the continued assistance. I have uploaded a complete screenshot as requested.
Micah
Nachricht 4 von 5
Activate Reveal Constraints and see if anything strange.
Nachricht 5 von 5
micah
als Antwort auf: ToanDN
@Alfredo_Medina and @ToanDN,
Thanks again for the assistance. I tried @ToanDN's suggestion for "Reveal Constraints," which I was not aware of. I did not find anything obvious with that, although there were two unrelated vertical constraints I removed, not knowing what they were for.
However, it then dawned on me that because of the slope I placed on the floor, the heights (Head and Tail) are controlled by:
1. selecting floor
2. Select "Edit Boundary"
3. Select Slope Arrow and modify in Properties Pallet
See the attached screenshot.
