Maybe, How about the phase filters?
The overrides are also dependant on the Material & Line color... So, check
the phase filter and see if, for your current setting, the existing phase is
overridden. In which case the "Existing" override will be used along with
Linecolor, line pattern and the Material setting...
I guess, what filter is being used in that view & what is the settings for
that filter in the "new, existin, demo and temp" catagories?....... Then if
it's BY CATAGORY it's using the setting from VG, if it's overridden it's
using the settings from the Graphic Overrides.
Hopefully that made sense. :o)
Paul Monsef
TSA architects, pllc
wrote in message news:4840661@discussion.autodesk.com...
Paul, no funny business here. Nobody else knows how to use Revit here yet.
I check'd the overrides and they are as follows,
existing set to Projection= 2 and Cut= 3
New Projection= 4 and Cut= 5.
Is there somewhere else you can set the linework?
John
