Floor Elevation mark
9 ANTWORTEN 9
Nachricht 1 von 10
356 Aufrufe, 9 Antworten
Hi, sometimes when I fix the elevation through elevation mark, It jumps to somewhere else. Thanks for help
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
Not quite understanding.  What jumps to where?
Nachricht 3 von 10
als Antwort auf: ToanDN
when I change the elevation code it moves to somewhere else. Thanks
Nachricht 4 von 10
I'm not following you as well, but I'm wondering if this might be related to, and corrected by the "Elevation Origin" setting (e.g. Project Base Point, Survey Point, Relative).
Nachricht 5 von 10
What is the host of the spot elevation?  A landing, a floor?
Nachricht 6 von 10
It is a floor.
Nachricht 7 von 10
I don't know why and I can't replicate the same behavior.  So my only suggestion is to change the elevation of elements from Properties, not from Spot elevations.
Nachricht 8 von 10
@ToanDN: what are you trying to replicate? I don't understand the issue.
Nachricht 9 von 10
Me neither. So I tried to do what she did and the spot elevation remained in place on plan.
Nachricht 10 von 10
Sometimes it remains at its location, but sometimes it shows up somewhere else, probably it's just a bug.
