so above shows an offset floor and has some parts taken off at the edges, but when i look at the floor boundary, it's completely just rectangle. what do you guys think is happening here. thank you
Gelöst! Gehe zur Lösung
Gelöst von TripleM-Dev.net. Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
I see two reasons for this behaviour:
Constantin Stroescu
Or:
- Shaft opening
- Opening by face
- Vertical opening
These all can affect a floor. (See Architecture > Openings panel)
that's right!
...could also be these functions cutting the corner of the floor slab.
Constantin Stroescu
I did not sense any shaft or vertical openings earlier but I need to try check again, thank you guys!
you guys where right! Thank you! stay safe there in the US (I assume), the outbreak's been worse there than here in the philippines.
