Floor boundary lines appearing on wall cut lines
2 ANTWORTEN 2
Nachricht 1 von 3
s.ng65
232 Aufrufe, 2 Antworten
Hi forum,
I am having an issue where pdfs exported with the raster setting enabled shows the floor boundary line on cut walls within my floor plan. Is there any way to fix or override this? attached screenshots show the issue
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: s.ng65
Check "Replace Halftone with Thin Lines" and see if that resolves.
Nachricht 3 von 3
Does it not happen if you print as vector?
