Hi! I have a building with an underground storey. I created a building pad and later the flooring above the level -1. The problem is that the walls and the colums jut out through the flooring and the building pad. (view attached)
How to keep it underground only?
I tried offseting from the top but it works only for the columns and not for the walls and floor.
I wan to arrange the surroundings near the building and these elements are pretty unwelcome :<
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
... did you try keeping the columns base offset at 0' 0"
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
... and for the walls did you try in modify/walls
... to attach to the floor?
aRcHiTeCt.JM
REVIT EXPERT ELITE
Marcello Sgambelluri's wicked cool approach, may have an application here as well.
Check it out, @dariawerynska. Good stuff.
