Flipping level tags
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
806 Aufrufe, 4 Antworten
Flipping level tags
Hello community.
Does anyone have any ideas, or know if i'ts possible to add a Flip control to a level tag so you can change the pointer under or above the elevation line??
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
You can create a TYPE that does that, or another Family. But NO, you can't do in "on the fly" per placement instance in the Project.
If you choose to have 2 TYPES within the one Family, you can use Visibility Parameters and a simple formula to control which side is Visible for Types 1 and 2.
....just to clarify, you need to Create another Level Type in the Project that uses the different Head -- which you need to create.  Then you can use one of those two Level Types in the Project -- but not both for the same instance/Level Type.
Nachricht 3 von 5
Enzo.CardinalBQSGA
als Antwort auf: barthbradley
I'm new to revit and I would like to know what would be the formula to control de visibility if you don't mind sharing it.
Regards.
Nachricht 4 von 5
als Antwort auf: Enzo.CardinalBQSGA
Select the element and look under its properties. See "Visibility" checkbox? Well, that Visibility YES/NO Parameter can be associated to a Family Types YES/NO Parameter.  Does that help?
Nachricht 5 von 5
Enzo.CardinalBQSGA
I'm familiar with the per type, what i don't follow is the or may be i'm misunderstanding something.
Can you have only one spot elevation family that does the flip automatically? or you must have two?
Regards.
