If I select a wall and want to flip it using the flip( little blue) arrows. This seems to push the wall to some random location.
As far as I know the only workaround is the mirror command. But it destroys the existing dimensions and tends to break the existing joins.
Try this:
-Select the wall
-Set alignment on wall center (top bar)
-Hit the spacebar
