Flipped building sections
2 ANTWORTEN 2
Nachricht 1 von 3
283 Aufrufe, 2 Antworten
hi all,
is there a way to control the annotations so after the section flipped it stay as it is.
my section 1 is original and 2 after its been flipped.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Annotation is view specific, these appear to be annotation and not tags. The annotation in both images appear to be in exactly the same location to me (the images are different scales which is a bit misleading)
Try using tags instead of text.
Hope this helps.
Nachricht 3 von 3
Thanks for your reply.
Those are tags by type mark not text.
Dimensions, text, keynotes Tags etc in Revit comes under annotations. I think you mean to say use tags not text
posted picture is just snap shot but the actual Revit scale is same.
