Flexing Nested Famlies
I have a fitting room family that I would like to nest, and use in a series. I am having trouble getting the room to flex width based on maximum room width and overall length of space to fill. I'm still new to nesting, rounding, etc. Thank you.
I'm not sure I understand? Do you want the stalls to automatically adjust their width to fit the room width?
...honestly, I think you did a fine job with this Array. I don't see any issues with it. But, if you do want to have the stalls adjust in width to accommodate the overall width of the space, it'll just take a few additional evaluation parameters.
I see one of your issues.  Parameters need be Instance -- NOT Type.
...see if you can break this family attached herein. No guarantees.
-Changed all parameters in Host to Instance.
-Changed Array to Append at End
-Changed Nested Family's Origin Plane and pinned it.
-Changed direction that the Nested Family "grows" in.
-Changed the Nest Family's "Width" extents to the outside surface of side partition walls
