Flashing Detail Problem
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
theresatlninhMWWN4
191 Aufrufe, 4 Antworten
I try to make a parametric flashing cap. Everything works fine, but when I load in the project the right square end does follow when I stretch it. I am trying to figure out what happened, but it doesn’t work.  Can you help me to look at it?
4 ANTWORTEN 4
Nachricht 2 von 5
nozci
als Antwort auf: theresatlninhMWWN4
I think you meant it does not move together because it is not right now. To move them together:
Align it to this dot. You can catch by pressing TAB key. And lock it.
And then click it again and unlock this lock by pressing the lock icon:
then it moves together.
Nachricht 3 von 5
theresatlninhMWWN4
als Antwort auf: nozci
I did the same thing you said, but it just doesn’t help. It only work for 1 thing, either verticals align or horizontal align.
Nachricht 4 von 5
Mike.FORM
The issue was you were trying to align your drip edge by rotating it in the flashing family and aligning to ref lines.
I edited the drip edge nested family and rotated it there and used the ref planes to align in the host family.
Nachricht 5 von 5
Thank you for your help, @Mike.FORM @nozci
