fix all dimensions of the entire project
39 ANTWORTEN 39
GELÖST
Nachricht 1 von 40
mohiroal
1375 Aufrufe, 39 Antworten
Hello
I have two projects when I tried to merge them by inserting the link I find one of them has very small dimensions I discovered a problem with the dimensions   (should be the small is 9million m2 area and the big is in small)
39 ANTWORTEN 39
Nachricht 2 von 40
als Antwort auf: mohiroal
Is the link brought in at the correct scale/units?
BTW: RVT Link Dims are only visible if you set the Link to "By Linked View" in the Parent View. Is that what you are doing?
Nachricht 3 von 40
Are they CAD files? Choose correct Units when link them in.
Nachricht 4 von 40
mohiroal
als Antwort auf: ToanDN
Isn't the correct units iam chosen 1st project when started default metric and 2nd project imperial metric now the first one is wrong
Nachricht 5 von 40
mohiroal
als Antwort auf: barthbradley
Nachricht 6 von 40
Huh? I don't understand the question/workflow. Can you elaborate?
Also, tell us: Is it a CAD or RVT link?
Nachricht 7 von 40
mohiroal
both are Revit. if you seen the screenshot u will see 2 projects the big one should be in small .
Nachricht 8 von 40
mohiroal
Nachricht 9 von 40
Post the RVTs here and we'll look to see what's going on.
Nachricht 10 von 40
mohiroal
"9km" is 3*3 km
Nachricht 11 von 40
@mohiroal wrote:
"9km" is 3*3 km
Nothing is wrong with this model.  Where is the tiny thing that is supposed to be 9 million sqm that you spoke of?  You need to share it as well.
Nachricht 12 von 40
mohiroal
file "point" should be here in "9km" . when insert a file  be like fiqure2
Nachricht 13 von 40
mohiroal
I am trying to merge both but "9km" is wrong dimensions
Nachricht 14 von 40
Is it 921 meter dimension correct or wrong?
Nachricht 15 von 40
mohiroal
all dimensions in this file are correct
Nachricht 16 von 40
mohiroal
problem in in "9km'
Nachricht 17 von 40
Then why don't you send the "9 km" one. There is nothing in this file that remotely 9 km.  If it is a link/DWG/image then you need to send it separately.
Nachricht 18 von 40
mohiroal
oh sorry
Nachricht 19 von 40
When link the DWGs in, choose Import Units = meter.
Nachricht 20 von 40
I don't see an issue right off the bat.
Can you point me in the right direction?
