Fittings are missing in 3D Ortho assembly
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
jw.vanasselt
781 Aufrufe, 6 Antworten
I'm missing my pipe fittings after creating a 3D Ortho View of my assembly.
How could this happend?
It's not a filter issue. the fittings are nested familys..
KG
Jan Willem
6 ANTWORTEN 6
Nachricht 2 von 7
martijn_pater
als Antwort auf: jw.vanasselt
Check if Pipe fittings Model category is turned on in Visibility Graphics (in template or otherwise)
Maybe check phase settings.
Nachricht 3 von 7
RDAOU
@jw.vanasselt
Check also the Visual Style...some are set to show only on Fine and/or Medium
Nachricht 4 von 7
MISSING SOMETHING IN A REVIT VIEW? 33 STEPS TO FIND STUFF:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Nachricht 5 von 7
jw.vanasselt
als Antwort auf: barthbradley
Thanks for the replys.
Non of this is the solution.
The fittings are nested family's look below. I can click the fitting:
Nachricht 6 von 7
jw.vanasselt
By the way, the fittings are visible in other 3D views. So it's a Assembly problem perhaps?
Nachricht 7 von 7
jw.vanasselt
