First floor roof disappears when I go to floors above
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
fortywebs
539 Aufrufe, 2 Antworten
Hi, when I look at the second floor plan I want to see the first floor extension roof, but it disappears, presumably because its eaves are lower than the second floor. How do I make it show? Oddly, it does show the gutter though. Thanks
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: fortywebs
Did you adjust your view range?  It needs to be set so that the roof below can be seen.
Nachricht 3 von 3
ennujozlagam
you can create a plan region in that portion and adjust the view range until you see the roof and hide the plan region in that view. thanks
