Fire rating parameter for column
lukearh
lukearh
How can I add a Fire Rating parameter for structural columns in Revit 2024, that can be tagged and works with filters?
azad.Nanva
you can use the shared parameter for tag and project columns.if you have old one for wall , doors ,etc you can add column in categories  too.
lukearh
Can you please elaborate a bit on the procedure?
HVAC-Novice
You create a shared parameter for your fire rating. The parameter type depends on what you intend to do. I use text.
then you make that shared parameter to be a project parameter and assign that to all categories you want (architectural and structural columns, windows, doors, floors...).
Edit: I use instance for walls etc. A specific CMU wall can be rated, or not rated depending on the location. But you also can use  "type" . But then you need to create more wall types. Same for columns etc.
Add that shared parameter to tags for columns, floors etc.
Using a shared parameter first, instead of just creating a project parameter outright, enables you to use it in tags and schedules.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
azad.Nanva
in the wall for example we have fire rating parameterr but this Built-in parameter and Type parameter and you can not share it with another element "Str Columns" in this case:
so i make my parameter over fire rating that can be used for all elements or You can create a special parameter for the columns in the same way:
